M35a2 from South El Monte Ca to Yuma AZ
Gunfreak25
Yuma, AZ
Trying to get an idea for transportation cost on a running driving M35A2 from El Monte to Yuma. Thank you
glcaines
554
Hiawassee, Georgia
If the truck is running and drivable, why not drive it? Costs a lot less money and can be fun. South El Monte is not that far from Yuma.
Gunfreak25
Yuma, AZ
I’m quite tempted to, but he doesn’t know when the last time it had deep service was (bearings, shoes etc). He rebuilt the air pak and takes it for small spins here and there and he said the tires aren’t too bad. But it’s also triple digit temps now and the heat likes to make gremlins creep up.
if I sell my m1009 this week I’ll be heading to El Monte to look at it and if I like it, buy it. If it was only $600 or so to ship I just assume do that and take any risk out of the equation.
It’s a pretty boring line to Yuma, good view of the Salton Sea along the way.
glcaines
554
Hiawassee, Georgia
Temperatures can get high and you can be miserable driving in high heat in a deuce, not to mention engine cooling. If you do decide to drive, I would recommend driving after the sun goes down and there are cooler temperatures, assuming that your lights are working well. I've recovered two deuces, one a 17 hour drive from PA to GA and the other a 27 hour drive from Wisconsin to GA. I enjoyed both trips, although the trip from Wisconsin was in the winter and VERY cold driving. Good luck.
frank8003
2,726
Ft. Lauderdale, Florida
If you like it then buy it and take it for 10 mile 25 mile 50 mile and up drives and then go home with her.
Take your recovery tools and especially your heat gun.
looks like a really nice drive
topo
farmington NM
GunFreak25 It is always good to see and read your posts .
I have had a hub get warm on the road on the way home and stopped pulled the axle and removed the outer seal and put the axle back in and parked on a slopping bank to let the bearings get some gear oil and came home the inner seal did not leak much . When getting a new truck home bearings and brakes are the first things that get taken a part lubed and fixed . I fully understand why you would rather trailer it .
Gunfreak25
Yuma, AZ
Yup among the many other possibilities. Any idea what I should pay for a 260 mile trailer home?
Gunfreak25
Yuma, AZ
It would roughly be about $800. If you need help getting it moved shoot me pm.
Here's a picture of the equipment I work with.
THANK YOU, we will more than likely be in touch. Can you message me your phone number?
G744
189
Hidden Valley, Az
M35 wheel bearings don't get oil. They are all grease hubs.
That is, unless your seals are bad. I guarantee, if you get oil in the hubs, it will find your brake shoes too, making a lot of unnecessary work to fix.
DG
NY Tom
358
Riverhead, NY
DG
I think TOPO was describing a bush fix method to get a hot bearing truck home.
But obviously you are right in your statement above.
ToddJK
Sparta, MI
I understand the concerns. Best to find the safest way if there is any doubt once so ever, Murphy's law loves to prove itself.
