Dasgog
- 151
- 43
- Tucson, AZ
Hello
So the Deuce is a '72 with 11,000 Miles on it so not a lot of wear and tear. Not too far off it was all taken apart and put back together and well maintained. I drive it once a week and usually not too far but it warms up enough and when I get home it goes into reverse just fine. This week I have noticed after two very long drives that when I return home, it will not go into reverse without the truck skipping and clunk clunk clunk and if I force it I know something will snap.
The only constant I notice is that it only does it after its really heated up.. On a fresh start after sitting it'll work fine.
The truck drives 1-5 gear like a dream and there are no noises whatsoever. Lever brake engages and I notice nothing abnormal.
Originally I thought maybe the gear oil was old and maybe wrong kind and getting too hot so I changed transfer case/transmission with 80x90 gear oil and today it did the same.
It does this in LOW and HIGH gear reverse... I engaged the 4x4 lever and heard it hiss and then it went in reverse fine in high/low and then brought it back to 2x4 high/low and worked fine.
Not sure if I got lucky or if there is something else going on.
Suggestions?
Suggestions?
