acesneights1
- 24
- 20
- CT
That was gonna be my next question. I believe my new motor has the oilpump off a 5 ton on it. I think the PO took the whole oilpump and pickup tube assmbly and swapped it to the LDS and put the 5 ton oil pump back on my LDT. Can I just use my pickup tubes with the 5 ton oil pump ? My LDT Oil Pump is loaded with shratnel. I would not trust it.Nah, not mandatory, just handy. I use a ratchet on one side and a box end wrench on the other. Why is the oil pan important? If it a multifuel, its just installed backward as a 5ton set up. The oil pick up tubes is what is different. You'll need to swap those. Also, if you put your trans in after you put the motor in, you will want the trans in (I think) 1st gear, as it sucks in the shift rod that sticks out the back of the transmission. That rod is only used in a truck with a sprage T-case, but it will still hinder your installation if it isn't sucked in.
Here's what was in the pan...I can't figure out why the motor made noise...
https://www.youtube.com/watch?v=IPHyKw1PQvY&feature=youtu.be
