- 12,196
- 315
- 0
- gainesville, ga.
The truck is NOT designed to keep up with traffic, depending on WHAT tires you are using, they may NOT be designed to keep up with traffic, the truck is NOT designed to STOP when kept up with traffic STOPS, even with duel circuit brakes and loosing 1/2 of the system will only cause a bigger event.
If YOU CAN NOT show the design specs for the truck to "keep up with traffic", in case of an event YOU can be found at fault or at least a contributing factor because YOU were EXCEEDING the designed speed of the truck and/or tires. If you want to "keep up with traffic" buy a CIVI pu, If an event happens because you were "keeping up with traffic", it makes EVERYBODY in the hobby LOOK BAD.
