M35A3/M36A3 In cab heater
Crazyguyla
124
Altus, OK
every m44, m800, m900 series trucks i've driven or ridden in had a sticker that said, "open dampers before operating heaters" i thought that ment the vents on both sides of the truck by near the floor. that would solve the fresh air requierment ;)
Marcus
Boatcarpenter
Marlborough, NH
I'm already working on a way to mount the firewall elbow with the flapper valve in it that came with the heater kit on the passenger side kick panel vent so that I can open the vent and then control the amount of outside air that I can let in right at the heater blower intake. That way I can let in some all the time and vary the amount depending on the outside temp.
cranetruck
94
Meadows of Dan, Virginia
Based on th winter driving I have done, defrosting the windshield is the number one use of the heater. The firewall gets plenty hot after a short time and keeps you warm.
Boatcarpenter
Marlborough, NH
CT, you are absolutely right. Part of the reason I'm trying this install is to maximize heat, especially defrost. I figured that with the heater mounted in the usual place there would be significant line and temperature loss by the time heat got to the passenger windshield. Also, I figured if it works, it would make working on the drivers' side of the engine VERY much easier. Time will tell. It's an interesting project and I'm enjoying doing it.
yeager1
Colorado
This may not be appealing to everybody, but one great way to maximize your defrost is to disconnect the rather poor stock system and install an aftermarket electric rear-window defrost system on the windshield. You will have those thin lines running across the windshield, but your now heated windshield will never fog up and you won't ever have to scrap it again. I did this for a friend on his scout and he loved it! You didn't really even notice the lines while driving. (He had been starring at a broken windsheild for 2 years, so he knew those little lines wouldn't bother him :) )
Boatcarpenter
Marlborough, NH
Does anyone know if the horn breaker is beefy enough to handle the heater running through it until I can get a dedicated breaker for the heater. I didn't get one with my kit. Or should I find an inline fuse to handle it until I get a proper breaker?
Thanks for any pointers.
BC
Desert Rat
BC,
Where you put the heater is where I'm putting my A/C unit for 'Storm. Funny how great minds think alike!!!!!!
Boatcarpenter
Marlborough, NH
DR,
I'm surprised you're putting A/C in, I thought you liked it hot :) You sure never miss a chance to let us guys in the cold climates know how warm you are down there!!!!!!!!
DrFoster
Cheyenne, WY & Condado, PR
If you want an even more compact and hotter unit, try the rear heaters for toyota landcruisers (76-79 models). There are several other companies that make these for jeeps too. I would suggest to look at man-a-fre for the heater if you have any interest.
DrFoster
oops-- forgot to include how easy these are to hook up... 12vdc on a three-way switch for the internal fan (low-high-off) and 2 coolant lines. It's about 6x8x6 in size and mounts almost anywhere. I'm going to be installing one in the back for hunting season.
Boatcarpenter
Marlborough, NH
Fresh Air
Right now it just comes in through all the leaks into the cab, but I am working on a way to get what I need in through the vent flap on the passenger side. Went for about a 20 mile ride the other day and no problem with recirculating cab air. In fact so warm in cab I had the windows cracked.
mangus580
283
Western NY
Wallew, I 'read' the copper line to be an extension of the compressed air line... so it was still accesible....
Boat, I figured that was the case for now...
why not make a manifold that fits over that vent? and maybe put a door in it to allow air direct into the cab as well? Know what i mean?
