M37 to modern MV brake lights
Soupermike
675
Plaquemine, Louisiana
Does anyone have a wiring diagram of how I can wire newer MV brake lights on my M37? I understand the original wiring harness will need to be changed, I just don't know what changes needs to be made.
Thanks,
Mike
Soupermike
675
Share the knowledge with those of us that want to do the same upgrade!
Sent from my iPad using Tapatalk
Pretty simple. I made a jumper from the #21 wire on drivers side to the passenger side drive light. I was under the impression that it would take chopping up my harness by info from someone on Facebook.
nattieleather
148
Cleveland, OH
It should be plug and play for the most part. You will have at least two wires that will have to go from one side to the other but it's just follow the numbers (if they are still there).
Left Taillight should be Service Stop, Service Tail, Blackout Tail Light
Wire # 21 - Service Tail
Wire # 22 - Service Stop
Wire # 24 - Blackout Tail
Right Taillight should be Blackout Tail, Blackout Stop
Wire # 23 - Blackout Stop
So, you will need to Y off of #21 #22 from the left hand side over to the right hand side so that both tail and brake lights will light. And if you want the black out to work then you will need to Y wire #23 from the right hand side to the left so that both black out stop lights will work.
A Volt Ohm Meter or trouble light is your best friend to making sure you have the correct wires going to the correct place. I would start with the brake lights first and get them wired on both sides and working. Then the tail lights and then the black out if you want them to work as well.
If you were near Cleveland, Ohio I would offer to come over and help you.... but this is the best I can do. Good luck!
Soupermike
675
Thanks nattieleather,
I did Y off of #21 but I didn't think of the stop light on #22. I will have to do that.
I appreciate the offer to come help. I alway seem to be too far from help and good deals on parts!!
fasttruck
637
Mesa, AZ
When I did mine I bought a new wiring harness and specified Packard plugs for all lights as the composite lights have Packard plugs. Stock there is one wire for the BO brake light which is mounted on the right rear part of the chassis. As you now have 2 BO brake lights you will have to rig a jumper from the right light to the one on the left. If your truck has turn signals the Army uses the brake light circuit to carry the turn signals.here is no separate brake light circuit as on a commercial truck.
