m66 ring and related questions
MilitaryRestoration
Vancouver/Yakima, Wa
We are getting ready to put our m66 ring on but a few questions have arose.
- One of rings is stuck, so I pulled lock mechanism completely out but still wont budge...any suggestions or do I need to do a complete tear down..?
- I had bought one of the reinforcement plates that goes into the cab area, but as light as it is, sure does not seem like it would do much...Let me know otherwise or if you used in your truck or not. If didn't anyone wish they did or notice any bending in cab...
*Picture of what I'm talking about below
Want to try and get it all installed by end of weekend so any quick helpful info would be Awesome! Thank You
FreightTrain
Banned
2,730
13
Gadsden,Al
well,the plate along with the 95 rivets will hold everything in place.Doesn't take much.Think of it this way,Find you some of that one sided cardboard(paper on one side and just the ripple stuff on the other.See how easy it bends and flexes?Now find a peice of double sided cardboard and see how stiff it is.Same idea.The plate is not a very structual element if say you put it on saw horses and stand in the middle but side to side it strengthens things like crazy.Also,the picture above shows it upside down.It goes with the notches at the bottom and all the way down on the hump.The notches are for the seatbelts and the holes are for the U bolts to the M66 legs.Allows you to gain access to the nuts.So,keep that in mind when you go to perminantly mount it.Make sure they line up or your in a world of hurt!
sermis
17
Temple, TX
I had my ring on without the plate. At the time I did not know there was a renforcement plate. I could tell the cab had some flex movement but it was while off road and puting it into a bind. I think over a long time it might cause some problems to the cab. 300#'s + up in the air on 3 legs has some torque flex. I have seen several trucks without the plate with rings and no problems.
FreightTrain
Banned
2,730
13
Gadsden,Al
Yea,You can stick the ring on.Just don't do any deep wood stump jumping.But don't wait 2 oe 3 years to mount the plate.The cab will crack at the doors and corners.
David_4x4
North Texas
Our ring had some difficulties spinning. I wound up taking the top off of it and giving it a good cleaning with some compressed air and nice lubricating afterwards. Now it spins effortlessly.
As for the reinforcement plate. We havent installed ours yet, but im sure in the near future. Our ring has been on the truck for probably 6 months now and our cab is fine with just drives on streets and parades. Like said though, I wouldnt go on any offroad adventures until that plate is in.
Dieselsmoke
CA/NV
Step 1: Flip the plate over...it's upside down in the pic. The slots go toward the bottom for the seat belt mounting locations. Oops, just read freight trains post he already pointed that out :D
FreightTrain
Banned
2,730
13
Gadsden,Al
Step 2-BUY A BUNCH OF 1/4" drills and a drill doctor cause your gonna need them!95 1/4" rivets per the Military TM.2 sizes due to thickness of material.The cheap Commie Chink air riviters will not pop 1/4" rivets either.You will have to either borrow or buy a GOOD one.
MilitaryRestoration
Wow...Thank You for all the help...the picture isn't of our truck just one I found off internet, did find a picture on SS of correct mounting so that helped, and thank you for the heads up on rivets as well. I think for now I will just mount the m66 ring and then come back and mount bracing plate later, due to time constraints. I think we will be making the reinforcing plate soon so give me some feedback for those of you that need one/some. Thank You again. -Todd
MilitaryRestoration
beware plenty of pictures
Ok so finally got the thing mounted...beware plenty of pictures
MilitaryRestoration
and more...
and more...
dabtl
Denton, Texas
RE: and more...
Don't you wish you had the straps for the ammo can holders? Sigh, so do I. Cannot find them anywhere. Oh, well, it looks good up and going.
Now all you need is a full auto M60 to complete the package.
kcimb
212
Fort Worth, Texas
Re: RE: and more...
You can get a semi-1919 that will fit for about 1k$ or a semi m2HB for 10k$.
maddawg308
762
Appomattox, VA
He's talking about authentic - real firing semi-auto .30 BMGs and .50 BMGs.
If you just wanted a replica up there, Jon Shoop makes the best replica .50 BMG I have ever seen. $795 for a kit or $1K assembled, and it looks SO REAL, even up close.
