gimpyrobb
dumpsterlandingfromorbit!
- 27,791
- 788
- 113
- Cincy Ohio
I got a call from him this afternoon. He said it had great brakes and they got it started, but it wouldn't rev up past much of an idle. Thats all I know.
thats what i would do, my 250 had a fuel problem (sucking air) and after i fixed the leak, i pumped till there was fule, and fired it up.. it wouldnt rev up any, so i just let it run for 15-20 min, and havent had a problem since..Today I moved it to the top off the hill in front of the house.
Checked out all the lines. Replaced a few rubber line.
Found a loose line line one the bottom of the ip going to the primer pump.
Opend the bleeder and pumped the primer till I seen fuel.
I cranked on it a few times and it started up.
But I must still have air in it. Its ideling faster then Id like so I shut it down.
Think I may just start it and let it run. See if it will idel down on its own
