Jersey4x4
- 1
- 0
- Absecon, NJ
I think this is the correct spot for this as this is a factory option on the trucks and not really a mod. I have an M816 and it does not have the trolly brake setup for towing and I want to add it. I found an outlet for the correct handle/valve which is the same as the air valve for the rear clutch valve. Anyway, I need some input on where the factory assembly would be located on the column and where the air lines get connected to the air system. I want this to be as it would on the truck tractor or the 5th wheel wrecker. There is/was a kit available from the gov. according to the TM but I can not find any sheets with installation instructions or where to connect it. Any info I can get would be great, Pictures also if possible. Thanks
