m139h2otruck
- 5
- 16
- NH
Try Sam Winer's for mirrors. On e-bay all the time under rzetzer. Around $22-25 each w/ head. Plus shipping of course.
Good looking big truck!!
NO kidding? Min clearance standard is 10FT.BFR said:not my truck, but...
btw the biggest hurdle was the power line overhead.
m139h2otruck said:Re your question about needing power to run the truck, the Cummins has an electric solenoid valve for the fuel shutoff. If not enough voltage, it would tend to close and shut off the fuel. Multis and the Macks don't have this, just the pull knob.
A Cummins 4BT weighs in at 700lbs give or take a few depending on what accessories you hang off it and how you configure them...No.2Diesel said:How much does a 4BT weigh? There is no front axle switch under the dash so I'm assuming its a sprag?
And even fewer have the scrawny deuce wreckers! LOLonly Gods chosen few have a 246 or a 819,
I've got an M819 and haven't seen this air switch. If installed, where would it be? Is this MWO common to all of the M809 series?73m819 said:there is a mwo for these, this is for a air switch that shuts the air off to the control valves on the trans, this allows the sprag to drop into neutral, this is for towing, (you can get stuck if the switch is not on ) ,
