wreckerman893
Possum Connoisseur
- 15,618
- 2,013
- 113
- Akenback acres near Gadsden, AL
I got the fuel line issue with the new (to me) M915 resolved.
Reinstalled the driveshaft and took her out for a shakedown run.....runs and shifts out good.
The batteries were dead so I had to slave it off.....she now has four new batteries installed.
She cranks good but there is a clicking sound coming from the box attached to the back of the alternator that I think may be a short or relay sticking. As long as the batteries are connnected the clicking continues.....I am keeping them disconnected to keep from running them down.
There is a big yellow wire coming off the starter that is burnt to the point the insulation is melted off. This wire goes into a harness that goes around to the front of the engine and comes out and goes into the box attached to the rear of the alternator (I assume it is the same wire). There is another smaller yellow wire that is equally cooked that goes to the same terminal as the big yellow wire. No other wires seem to be affected.
The headlights, turn signals and flashers work but none of the electrical guages are working (oil press, voltage). The Jake Brakes are inop now too.
I opened all the panels on the dash and did not see any signs of short circuiting or cooked wires. Didn't hear any clicking coming from the breakers in the dash.
I don't have a TM or wiring diagram for the truck so I am shooting in the dark.
My big fear is that the alternator is cooked......I am sure they aren't cheap and I am on a low budget for repairs until my VA check kicks in.
Any ideas from the educated masses????
Here are some pics. First two are on the starter side...the rest are from the alt side.
