R Racing
- 17
- 38
- St. Leonard, MD
There are a few things for you to look at,Look under the dash left of the steering wheel should be a small yellow box. thats the flasher relay. there a common fail item. next check both rear tail lights. the way the internal wiring to the light is horrible and are know to rust thru. ( ask me how I know !! ) Also check your CB's with the the power on and make sure you have power on bothe sides . Some of those have a internal Diode and if installed backwards dont work correctly.
