M915a1 question on drain plug
Autocar
California
I'm going to recover an M915A1 next week and I want to check the rear diffs oil levels. Does anyone know where the plugs are located and what kind of wrench they need? Thanks.
fasttruck
632
Mesa, AZ
I do know it is the larger and/or upper plug. A second hole is provided by the manufacturer (the lower one) for a temperature gauge which is not used. Will look at truck tomorrow for size. Most are 1/2" drive square but there are others.
fasttruck
632
Mesa, AZ
Looked at truck today. M 915 not like 809 series. This has a 3/4" square boss on the check plug so an open end wrench should do. Check-fill plug is the higher and larger one on the rear of carrier. Pic attached. Plug is visible beneath right tail ligfht. Smaller and lower plug is for a temperature gauge sender which is not used.
fasttruck
632
Mesa, AZ
One of forward rear or intermediate axle is same: higher and larger plug also 3/4" boss faces rear of truck. Takes about 4 gallons of GO to fill each one if they are empty plus a couple of quarts for the power divider on the forward axle.
fasttruck
632
Mesa, AZ
Yes the power divider has its own fill plug which is different from the carriers as it is a pipe plug with a 1/2" female boss which would require a 1/2" drive to get it out. Pic of LO attached to show its location. It will probably be easier to remove the deck plates between the cab and the fifth wheel to get to it. Taakes 2 pints of GO sez the LO.
