M923 Dump Conversion with 8" dual stacks
Bjmca
13
Northeast PA
any picture of the hinges that go on the back end of the bed to connect it to the frame? Im planning to get the CCE dump bed kit for my tractor conversion
Maybe later when it stops snowing I could go out and snap a few of the hinges. They came with the kit I purchased.
I know alot of guys would like to hear it run, but i dont really know a good way to record it and post it. I'm not that computer savy!
1,540
62
Riyadh, Saudi Arabia
Is there anything you would recommend for the installation that is not included in the kit? Id love if someone did a step by step write up with pictures. Ive been thinking about what the best way and in which order to install the bed and hydraulic bed lift, taking into consideration both proper placement for the best maximum lift and safety while doing the installation. I doubt I will access to a crane or anything to hold the bed up while doing the installation. One question I have about both the hinges at the end of the bed and the hinges at the lift is are they separable? Meaning would I be able to install one side of the brackets on the bed one side on the truck and then when im ready for finally assembly just mate the two together using pins or bolts.
wrenchturner6238
35
Beaver Oklahoma
I enjoyed this thread and you have built a nice truck!!
I am working on a M931 project but I also have M923 that I want to install a c&c bed hoist kit on the truck but i seen in this thread u talked it is easy to over load the hoist. I am wandering how full the stock bed is and it is over loaded?
Carlo
21
palazzago italia
I would love to hear it! I'm trying to find a single stack open for my A2's here but can't get the right diameter. Is there anyone in the US offered a single stack semi bolt on?
71DeuceAK
466
Fairbanks, Alaska
Is there any way to leave the spare tire in place but still have the bed dump? (I can see where having a full load of gravel could be an issue). Also what about just straight piping with the 8" stacks? How much of a performance boost do you really notice, is your fuel turned up too?
I like this... when I get mine (probably an A2 though) I might consider doing something like this, particularly if the stock exhaust has a rusted out muffler or busted stack...although I'd probably just straight pipe the dual 8 inch stacks, I happen to like loud exhausts!
