M923 frame length
lakeydna
Devon, AB
I've read on here the M931 frame is 11'9" from the cab, I've seen mention the M923 frame 12" longer. What does it actually measure from the cab? What about M927? Just trying to figure out what frame to use? I've found the wheel base measurements but want the actual frame lengths. Thanks
doghead
4 Star General /Moderator
1,188
NY
Dimensions should be found in the -10 TM.
lakeydna
Devon, AB
Thanks, I read slower and noticed my computer is skipping pages on the TM's.
What I've found:
M931 - 265"/ 22.1'
M923 - 307.5"/25.6'
M927 - 380.9"/31.7'
Assuming cab length is 10.3' based on 11'9" frame length extended passed cab on a M931, frame lengths should be as follows:
M923 - 15.3'
M927 - 21.4'
I didn't see any actual lengths I'm looking for in the TM's, just wheel base, chassis and overall. Any takers to verify my math?
hot rod deuce
Kasota, Mn
A 931 is 11'9 after the cab and a 925 is roughly 15'. The cargo is much more because it hangs over the rear, the cargo wheelbase is only 12" longer.
Don't forget the spare tire and muffler are behind the cab also.
tamangel
19
Nor Cal Coast
found this thread and thought I'd pose a different question.. frame height for an M927/814 is about 3'-4' or so(ground to top of frame)? Thinking along the lines of the Extreme Camper M36 project and this mod install for the basic structure..hopefully on the used market somewhere....
http://dahlsonindustries.com/projects_csc_dnv_containers.html
they come in 2 heights so hopefully wouldn't end up too tall..
Just thinking in and around the box...
Mike W
The opposite for courage is not cowardice, it is conformity. Even a dead fish can go with the flow.
Jim Hightower
