M923a1 failure, need input.
elkhtr
12
Stanwood, Wa.
Don't forget either to put the caging pin assemblies ( i.e. 'pin" the brakes) in the rear brake chambers or supply air between the towing vehicle and the towed truck to keep the brakes released. 809s and such did not have this issue.
Thats funny, when she broke down the driver of the semi wrecker hooked up to it and was trying to retract his boom with the hydraulics.
Had to remind him that with air the truck will roll much easier.
elkhtr
12
Stanwood, Wa.
M923 Deadlined-water in the oil
Some of you may have seen the thread on the inital failure.
Drained the "oil" got thirteen gallons where there should have been seven.
Pulled the pan, no chunks, all looked good.
Refilled cooling system, pressurized to about 15 p.s.i.
Coolant began to drip out around #1 piston.
Several members have offered up help, both physical and reasonably priced replacement engines.
Thanks Gents!
At this point I think I will pull the liner to determine the cause before a final decision on what to do, repair/replace.
Couple of questions.
Does anyone have input on the liner pulling tool, can one be built at home that is adequate to do the job.
The pics in the tech manual of the liner puller left a little to be desired.
To those who have done this, how much force does it require to pull it, pounds, tons?
Any advice, what not to do, or watch out for.
Thanks.
Suprman
707
Stratford/Connecticut
I bought the liner kit used on eBay and used it on an 8.3 sleeve it's turn the end till the sleeve lifts out basically like any puller. The 8.3 sleeve came out pretty easy. It had eaten a ring so although scored and scraped the sleeve was intact. You may be able to rent a puller somewhere. I personally like having tools around you never know when you will need it again. It's a big suitcase thing full of gadgets.
elkhtr
12
Stanwood, Wa.
I looked on ebay, didnt find a puller for the cummins.
found some online, but hey started at 600.00
I have machining and welding equipment, if it doesn't take tons of force I can come up with something.
Tech manual showed an installation tool also, I need to read up on that.
162tcat
Washington
Try a local diesel shop. I borrowed some specialty tools from a mobile mechanic once, he was very interested in my trucks. The 855 engines are still common but not many people rebuilding them so the tools are out there.
wrenchturner6238
35
Beaver Oklahoma
Hello
If you have equipment to machine; you could make a plate made with a lip for the liner so it will pass through the hole in the block and use a hydraulic jack and an extension to jack the liner out of the block. This liner will be fairly easy to push out it is NOT like the newer cummins that are lower press fit. The possible cause of you coolant leak could be cavation which is not taking care of the coolant. DCA is very important in a diesel engine ( just for your future info)
elkhtr
12
Stanwood, Wa.
Hello
Interesting idea pushing it from the bottom, the crank is still in the engine, if there is enough room I might try that.
swbradley1
Modertator
1,945
Dayton, OH
You could buy a tool or just make one similar to this one couldn't you?
swbradley1
Modertator
1,945
Dayton, OH
No idea but I'm guessing yes. Heck, if you make one make the legs removable and have a short set and a long set. Me I would build it heavier and just have it tall.
That is just a picture I got off the Internet.
Do a search on Google for diesel engine sleeve puller and click images and let your imagination run wild. ;-)
elkhtr
12
Stanwood, Wa.
You turn the journal of crankshaft to the side; It will get out of the way enough for the extension to go through.
Gonna ask because I've never done it before.
What is the best way to rotate one of these big buggers by hand?
Or do I have to bump it into position with the starter then pull the rod bolts.
wrenchturner6238
35
Beaver Oklahoma
Dont bump it with the starter. (something bad could happen) use a 1 1/4" or 1 5/16" 3/4" drive socket and turn it over on the accessory drive pulley nut. It won't turn over that hard.
o1951
155
Bergen County, NJ
Right! I also suggest removing battery cables as an extra layer of safety. To make fine adjustments, I have moved it with judicious use of a big blade screwdriver in the ring gear teeth, and shaft against bell housing. I say judicious because you are not honking on screwdriver. Just moving it a bit to line things up or get clearance. No compression is being built up, so as wrenchturner says, it turns easy.
hailstone
Arkansas
the seal around the liner could be bad or the liner may have a pin hole in it Also check the oil cooler for leaks. I have used a hydrolic jack and a piece of wood to push up the liner on the 350NTC Cummins. Worked real nice doing it in a truckstop over labor Day weekend about 20 years ago. JMO
elkhtr
12
Stanwood, Wa.
Update! m923 water in oil, need advice from the gurus.
So it's cavitation erosion.
Any one who has fought this battle before, I would love to hear from you.
If it has occurred in one cylinder, has it likely chewed on all of them?.
Thanks Wrenchturner6238 for your suggestion of pushing the liner from underneath.
I machined a block of aluminum to fit, hit it with the Enerpac, and out she came.
It did start to lift the truck before it popped, tools and parts were raining everywhere.
The only good news from this weekend is that the Mutt's heart transplant is looking good..
Looking forward to some sage advice.
juanprado
3,238
Metairie/La (N'awlins)
Thanks for the update.
Interesting article here on cavitation erosion.
http://www.forddoctorsdts.com/articles.html/_/dtsarticles/cavitation-erosion-r27
Best of luck with your rebuild!
