dougnash
- 49
- 18
- Long Island NY
Yes all fuel lines are getting replacedReplace all the rubber line while your putting Teds tubes in.
Hey Tedcat. I Possibly want a pickup tube.I make the new pickup tubes. I have one set available and more in the process right now.
When I send out the tube kits I suggest replacing all fuel lines with Parker Pushlock brand hose. It meets all requirements, is easy to use and very easy to repair in the field if that ever happens.Did you replace the fuel return line? I think that is what it is called. Mine cracked and I bought a nylon replacement. Trying to find someone who has used this part before carving up my original one. Thank.s
However the nylon has its benefits as well. The downside of using the original tubes is the inverted flare fittings are not as easy to find parts as the JIC fittings.
The engine already has a barb that is compatible with the pushlock. Carefully cut the old hose from the frame off without scratching the barb fitting and that end is ready. The tank end will require something like a ln inverted flare to NPT or JIC adapter then a barb into that.
What variant is your truck?
Hello Ted, I am interested in this kit. How can I arrange payment?Hi Kyle. I can have a set ready to ship later this week. I sell the kit for $250. That includes
-1 pickup tube and barb adapter
-1 return tube and barb adapter
- enough stainless steel antizeize/sealant to complete the job
-shipping
PayPal friends is my preferred method of payment.
I'd be happy to answer any questions you have.
What kind of truck are you installing them in?
Ted
