M923A2 muffler eliminator pipe ??
Carlo
20
palazzago italia
Is there anyone offering a muffler eliminator pipe for a M923A2?
It would be easy to make if the (before muffler) head pipe and the curve (after the muffler) pipe after the muffler did not have the "bevel or joint".
I searched archives but found nothing. Does anyone sell this?
Thanks Brothers!
Tornadogt
Adkins, Texas
The Band Clamps that attach the muffler on both sides are available. I have to move my exhaust to clear the bed I am adding. I will take photos of the muffler removal and record the straight pipe exhaust sound by next weekend.
Artisan
227
CDA Idaho
Did you make that recording?
Where did you get the clamps from?
Pics?
TIA!
goldneagle
906
Slidell, LA
You could have solved the relocation issue by just using a round muffler like the 18 wheelers use and install the stack on the side of the cab like the 18 wheelers do.
Tornadogt
Adkins, Texas
I received all of my tubing this week and will be working on the pipes this weekend photos and vids as I go..
I went with another air intake piping set and modifying it to be a mirror image of the driver side with out the mushroom cap
Hamilton, NJ 08690
Very nice. I was contemplating doing something similar but I was able to find that 4' length of 4" exhaust pipe laying around.
My current thought, and possibly next attempt will be to run a 5" straight up through the hood if I can figure out a way to cleanly install it with the tilt front hood setup.
Tornadogt
Adkins, Texas
The exhaust in front of the cab? Now that would be LOUD..
doolest
Fort Worth, Texas
thanks tm360...our m923 came with a large hole in the bottom of the muffler...we are too cheap to spend $300
for a new one when it doesn't ever see pavement...if the sound level is about the same then I think this is a good approach for us too...thanks for asking the ? carlo
Tornadogt
Adkins, Texas
If you want a Direct Replacement and want to come and get it you can have the one I took off.....
Suprman
672
Stratford/Connecticut
Jcwhitney used to sell a cheap exhaust bypass valve you would pull the lever it would go wide open on the highway and you could close it and go muffler on city roads
Will
524
Hamilton, NJ 08690
So you used 4 inch O/D tube and 4 foot in lenth?
I used 4" exhaust pipe. It was a leftover cutoff section, I never measured it but I would say it was 4'-5' in length (I don't think it was a full 5' though).
Mine is kind-of a hack job, it was done quick without purchasing anything. I removed the muffler heat shield and muffler. Cut the v-band flare off the exhaust just behind the cab, the 4" exhaust pipe I had slid in the connection and I used a 4" band style butt clamp. I had to cut the muffler mount towards the top and reused the stock hardware and muffler heat shield. I'll take a few more photos this weekend to make it a little clearer.
