M923a2 weak point.
mdmorgan
AM3 U.S. Navy
1,085
104
Forsyth, Ga.
I was real surprised just how much even small trees want to stay in the ground, I used the boom lift on my M936 to pull a couple Bradford pear trees straight out of the ground, they were less than 6" in diameter and I had to put the rear outriggers down to keep from lifting the front tires off the ground. I just put tension on them and waited for it to start to move then added more tension and waited, ect.ect.
crasheej
Hermitage,MO
I see the same thing all the time here with my help. They want to use a chain that is to small for the job. Then they get mad when I tell them to get one of the bigger ones because they weigh so much more. My answer is tuff. Any way use a chain bigger then what think you need.
1,185
Food for thought, ever see a tree company using a truck to yank out a stump?
If it was a good idea, don't you think millions of truckers would pull stumps, while waiting for loads to haul?
maxtor
California
On to plan C
Plan A was to use a chain and M923a2 and pull out tree stumps. :tank:
Some on this forum said I would break the chain. So
Plan B was to use steal cable and M923a2 and pull out tree stumps. :driver:
Now I have two "halves" of a steal cable.
On to plan C
Plan C , find a stump grinder.:roll:
Triple C
NAPOLEON MO
Wow, how about more info on how you came to have two halves of a cable? Where you using the winch? What size cable etc..... More info please.
Ooops, just realized you were using a 923! Scratch the winch part but still interested on what happened.
F18hornetM
10
Ocean City, Md
Tree stumps are unreal to pull out sometimes. I like the push over whole tree with excavator method!!! 8) I'm sure you know if going to pull out need to do a lot of digging and cutting roots.
jw4x4
Dayton, Ohio
I have extensive experience in clearing tree stumps. Heavy equipment or a stump grinder are the only way to go. I know there are isolated circumstances where they can be pulled (I admit to pulling a couple myself) but it seems as though stumps are way tougher than they appear. Save the chains and cables, avoid potential danger and injury (or worse), and do it the right way. You'll likely be far better off.
Scar59
41
Mt. Eden, KY
923s were desiged to haul cargo, stump grinders are designed to remove stumps. Good experiment. A+B=C
1,138
I am surprised the rope is what failed-I figured there were a whole host of things that would go first.
Was the rope flawed? Rusty, kinked, flattened, etc.?
Coffey1
499
Gray Court SC
When I was pulling trees with my deuce winch and they hang up it was always the chain or strap that failed. I tried to pull a stump and it was the shear pin that failed. I don't think your ever going to hurt the tuck unless its a weak tree and falls on truck.you just can't the traction.Maybe a truck with full lockers on good ground you might twist a drive shaft.
dmetalmiki
2,031
London England
A large shovel would be a nice way to go.....on the front of a buldozer! (or similar)..like triple C I would like to know what broke and how exactly..hope NO ONE was standing in the imediate vicinity when the breakage occurred though..santex works wonders with about the same danger.
Storm 51
Just a Grunt
9
Seattle, WA
I usually don't have any problem pulling stumps because I leave about 6 feet of stump to use as a lever and I do the pulling after a good soaking rain. The long lever just pops it right out. It takes longer to hook up and untie the stump than to pull out.
I just use my little M-37. I don't own any monster trucks.
Storm 51
maxtor
California
It was a near new 3/8 inch steal cable. It broke in half in the middle of the cable. The cable just snapped. Of course, no one was around and I was in the cab of the truck. No safety issues here. Where the stumps are, I am unable to push them, just pull on them. Like I said before, I will find a stump grinder and do plan C. This experiment proved that the truck and stump are stronger than the chain or cable. Now if I had a loggers cable or chain, 1/2 inch or larger, maybe it would work, but since I don't, plan C will be implemented.
