farmerboywyotech
- 4
- 18
- Argyle MI
Ok what if i put a selector valve in and run a separate circuit. I have a 15 gallon reservoir im gonna try and tie into the original. Might tie all 3 together not sure yet. The factory control valve is open center correct. which means oil flows through until the lever is moved then it redirects to the winch motor. I know that it has an open center spool but thats not the same as open center hydraulics. If the oil dead heads at the valve then its actually a closed center system. Ill get pics of the other pump and motor i intend to use. Unless someone has a 3 spool valve they wnat to off. Otherwise the truck system is all factory.
Sent from my SAMSUNG-SM-G890A using Tapatalk
