M925 winch info needed
74M35A2
340
Livonia, MI
Will do! This is a BIG plow with massive, angle cylinders. The lift cylinder is a lot smaller, but I think I should be able to regulate the speed with throttle and maybe a little finesse of the spool.
I hope to get back on this in a few months. Looks like farmerboywyotech might get to do some testing before me.
Too many amps! Wait, in this case, it would be too many gallons, or not enough. "Power Beyond" always sounds like something from Star Wars. In reality, it means a valve whos return (Tank) port that can handle pressurization of a second valve further downstream of it, vs one that can't?
Argyle MI
It actually has a seperate out flow that lets the pressure free flow through when not using it.
Sent from my SAMSUNG-SM-G890A using Tapatalk
Jbulach
2,400
Sunman Indiana
So i finally looked hard at my pump and it says right on it that its vane pump not a gear pump
Correct, mine is a Vickers 26VQ-14-A-1-C-20.
Max ratings 27 GPM, 3000 PSI, 2700 RPM, 62.5 HP, inlet vacuum 5" of Hg, inlet pressure 20 PSI, using SAE 10w.
I have not verified my PTO ratio yet, but apparently the max allowed operating engine RPM of 1800, puts to pump at it's max of 2700 RPM. Going by memory this theory matches the ratio that tobys came up with in another thread.
Jbulach
2,400
Sunman Indiana
Let me take a guess at it...
Your dump bed valve, power beyond outlet, flows freely when it is in neutral and connects to the inlet of your winch valve and can handle pressure, when the winch valve is activated. The tank return on your dump bed valve only flows the fluid that was used by it's work ports, in this case the oil that exhausted out of the dump cylinder.
