M925a2 horn/horn solenoid issues!! Air or power supply? Whats the trick??
hokie8358
backwoods ,virginia
I just got my first 1993 m925a2 truck about 6 weeks ago. Horn worked fine the first couple times i used it.
After i got it to the house 275 miles later and it sit for 3-5 days,nothing!! Would not make a peep or nothing after pressing horn button. Heard a couple solutions and tried them. Took horn apart at column. Button look great, female plug in column looked great. Checked with a volt meter with switch on and it showed 21.9-22.5 volts. No rust or corrosion. Checked solenoid with test light, nothing on either side of solenoid. I could not get a voltage reading either at solenoid. This has got to be an easy fix or i am over looking something. Plugs on solenoid look fine as well, no corrosion! Dealt with cucv's for so long, stepping up to the big boys now!!
74M35A2
318
Livonia, MI
Mine was a diode I think on the ground side of the horn under hood. Try that also. Points to WildChild467 for finding and fixing it for me.
