Most all parts can be found thru local sources in the link below. If you need something specific that isn't available locally let me know. I have a parts trucks.Do u have any recommendations of where to order parts for truck?
Thanks again. You are the bestMost all parts can be found thru local sources in the link below. If you need something specific that isn't available locally let me know. I have a parts trucks.
5 Ton Parts List- copywrited 2021
Sheet1 r,VENDOR,PART #,VENDOR,PART #,VENDOR,PART # M939A2 & M915 PARTS AT THE BOTTOM OF THE PAGE SYSTEM CAPACITIES Cooling System Capacity M939A0/1 w/ NHC250 Oil Capacity w/ Filter (w/o filter),27 Qts (23 qts) M939A2 Oil Capacity w/ Filter (w/o filter),20 Qts (18 qts) Allison Fluid Capacity Dry...docs.google.com
