M932A1 with shorter drop side deuce bed
rrrr
Missouri
Got two replacement corner bolts and nuts for the two that were bad. Installed those and rewelded the little steel ring retainers so they won't fall off. I think I have a line on a new cover to cut down so waiting to see if that happens.
Hopefully weather will cooperate so I can grind the welds and prime and paint the bed for a finished look. I hate when work gets in the way of the really important stuff;)
emr
25
landing , new jersey
I shortened a cover once because i had a wreckerset # 7 in back and wanted 1/3rd bed covered, i had a new 3 color vinyl with attached end curtains, I cut off the back end curtain folded under the the cover untill desired length and put a rope thru while i was folding under when it was just 1 ft past the last bow I pulled the rope and it looked and worked just like a regular ol canvas curtain with no end covers attached, it folded over just nice, the other bows held the curtain under, just a temp thought for U unitll u get a nice one the right size, :)
rrrr
Missouri
I thought about that. Found a local guy that has the right equipment that will cut and sew to length a cover for $75. Not too bad for a custom fit cover. Now I just need to get with papacom and get the stuff !
indy4x4fab
Banned
1,711
41
indy, indiana
Now I just need to get the cover from papacom and repaint the troop seats.
I can help with that, Treessw will be going past him on his way to me, and me and sparking are planning on making a trip out to glens scrap yard to get my tires and drop off us tow bar that i need to get back from you. Make sence to you. just toss us a couple bucks for the fuel.
rrrr
Missouri
Actually I'm going to meet up with papacom on Saturday after I go to the show of shows in Louisville. Thanks for the offer anyway.
rrrr
Missouri
Got the camo top kit from popacom. Today's weather looks great so out to do some painting and get the tow bar mounted on the front of the bed !
rrrr
Missouri
No other pics. Not hard just used two front shackle mounts that I cut off the 3rd mounting hole. I used 7/8 x8" bolts to mount the bar on the shackles.
MyothersanM1
19K M1 Armor Crewman
435
68
Culver City, CA
That is a nice and effective use of space between the bed and spare tire/utility box rack. Ingenious mounting points[thumbzup]. Which bed lining product did you use? Did you sand/media blast prior to application or apply straight up? I have been wanting to do that since I got the truck.
rrrr
Missouri
Plasticoat bedliner in the 1 gallon pale. I used a variable speed buffer with 80 grit sand paper to knock off the rust and loose paint and create a surface for the liner to grab on to. I put it on with a paint roller.
srodocker
70
Lacey, Washington
that towbar mount is awesome. how long is the truck compared to a full length deuce? about same size? or little long because of the nose?
about the towbar mount how is the lunette secured? is the bolt through it as well?
