Air Lines and Electrical progress
This weekend I concentrated on moving the wiring harness forward and determining the best spot to cut the wires, and add in about 7 feet of wire. Where the wire originally went into the cab on the M932A2 has the least amount of wires. All the tape is striped back, and wires that stay outside of the cab are pull back. My wire will arrive tomorrow from Eriks Military & Industrial Surplus from Escondido California. I have to say I highly recommend him for his parts. Great prices and good selection of part. Splicing of wires will begin this week. I will take photos and document what path the wires take.
I also ran all the new air brake and air accessory lines this weekend. I removed all the M932A2 fabric cover lines, as they would have took multiple adapters to hook to the new air lines. I disconnected the fabric cover air lines where they connected to the original nylon air brake lines. I went through 100' of 3/8" line and 80' of 1/2" and so many fittings. Air brake line and conversion cost so far around $330.00. Still need to go and buy an additional 20' of 3/8" and various fittings to complete the connections.
Started to hook up the lines inside the cab to the new lines. Here are the numbers that connect outside/inside the cab that I am using:
Front Axles Switch - from M932A2
71 - Air Supply line from Vacuum manifold in center section of cab compartment
706 - Delivery line to transfer case (not used for M932A2 conversion) replace MK-48 switch with M932A2 switch
69 - Delivery to front axle.
Service Brake Button
611 - Supply Air line
612 - Delivery Air line
Trailer Brake Button
611 - Supply Air Line loops from Spring Brake button
662 - Delivery Air Line
Trailer brake lever - Johnson Bar (on truck/tractors only)
27 - Supply Air Line - comes from vacuum manifold
663- Deliver Air Line
Air Throttle
415 -Supply air line for air throttle pedal
416 - Delivery to engine air throttle
Air Horn
38- Supply line is fed from vacuum manifold in center section of cab compartment39
39 - Delivery line to air horn, comes down through the middle of the cab into open area.
Air pressure gauges
610 - Primary air pressure gauge
041 - Secondary air pressure gauge
Tachometer and Speedometer cable
I will add a pass-through connector to both the speedometer and tachometer cable. Re-routed the cables, and the tachometer cable comes almost to the front of the cab, and will need a 3-4ft extension cable, and the speedometer cable comes about 10" forward of the back of the cab and will need about a 7' extension cable.
Ordered 1 side step for the cab, and looking for 1 more, and the chain drop down extension step for both sides.
A few photos attached, more to come once the air lines are tied down.
![20150607_125137.jpg 20150607_125137.jpg](https://www.steelsoldiers.com/data/attachments/384/384660-5dadf9f8cee0ddee14f3a06e7d836a97.jpg)
![20150607_125132.jpg 20150607_125132.jpg](https://www.steelsoldiers.com/data/attachments/384/384661-1bf8158794e1941f9b1b2e8eca1b5850.jpg)
![20150607_130822.jpg 20150607_130822.jpg](https://www.steelsoldiers.com/data/attachments/384/384662-72956daad8647db48ed73b47b786176c.jpg)
