M936 Power Divider - Incredibly Stiff
19,735
My M936 seems to operate differently than the 9-2320-260-10 (Page 2-13) shows. Item 6 in that list says "lever is pushed forward" to provide power to auxiliary equipment. Looking at the picture in that TM, it is obviously a manual transmission and mine isn't.
In my truck, that (power divider) lever just inside the drivers door is lifted up / pushed toward the back of the truck.
It is incredibly stiff. I have sprayed the linkage that I can see right behind the cab to attempt to limber it up. I saw a video that sometimes the transmission needs to be bumped in and out of gear to help engaging...
The transfer case lever is raised to allow winch / boom operations. That lever required a lot of wiggling and it seems to be stuck in the "up" position at the moment...
I don't want to force it, so I wiggle it some. Engage the transmission, then move it back to neutral while wiggling the lever again. Am I missing something? Should I be hunting more linkage to lube?
Evil Dr. Porkchop
279
Colchester, VT
Here are the manuals you want to read, you’re looking at the book for an earlier model truck.
M35A2-AZ
391
Tonopah, AZ
I think there is some grease fittings under the drivers seat, I think. Yes I have to move my lever to the back to engage the PTO, also need to have the transfer case in Neutral and may have to move the transfer case lever up and down a little. Also I have found you may need to let the truck row a little to get it to engage.
19,735
Thank You. I still have a hard time understanding how "939 Series" is what these trucks are called. Most times numbers go up. Maybe a "930 Series" would have made more sense to me. Especially since my truck is a 936.
I really appreciate the link to the proper TM's. I have them downloaded and will definitely make use of them!
19,735
Thanks! Feels good to know my truck isn't backward :cool: . I started at the back of the truck with a grease gun. One tube of grease. I have replaced about 20 zerk fittings so far and ran out of grease. I will be hunting for another behind the seat... The Transfer Case lever is a little stiff too so maybe I will crawl under and look.
charlesmann
713
Temple, Tx
Both my shifters are super tight. I sometimes have to put my xmsn in 1-5 to get the t case lever to fall in place. Same goes for the pto lever, t case in neutral, xmsn in 1-5 and apply pressure to the t case pto lever for it to engage.
19,735
Thank You! I grumbled at it again this morning. TC didn't want to go into low or high range. So I just played with the boom and winches. :unsure:. Worked on the outriggers some more. I will give your suggestion a try when it cools down a little and report back.
Power divider by the door - it works well now. I followed the linkage based on recommendations from
M35A2-AZ and found one grease fitting under the drivers seat. Shot it with one pump and that helped a LOT.
