sweetk30
- 6
- 18
- horseheads,ny 14845
working on the 936a2 with the 8.3 cummins and need to swap the compressor out .
the used engine we had installed had a comp on it . but the unit was never checked and now its installed it has a bad head gasket . huge amount of air out of it .
so by the looks of it its pull the comp off the engine or remove the injection pump that I do NOT wana do .
so I have the used comp off the old motor and it was good and hand spin has good comp stroke .
I did a search under air compressor and got to page 5 with no real results .
looking for the gasket #'s for comp to t-cover / adaptor on back of comp to let you bolt up the p/s pump and p/s pump to adaptor .
if there is even gaskets for the last 2 .
looks like I need to drain coolent also to do this job .
any help would be great guys thanks !![Thumbs Up [thumbzup] [thumbzup]](https://www.steelsoldiers.com/images/smilies/icon_smile_thumzup.gif)
