m936a2 air comp change out help
sweetk30
9
horseheads,ny 14845
working on the 936a2 with the 8.3 cummins and need to swap the compressor out .
the used engine we had installed had a comp on it . but the unit was never checked and now its installed it has a bad head gasket . huge amount of air out of it .
so by the looks of it its pull the comp off the engine or remove the injection pump that I do NOT wana do .
so I have the used comp off the old motor and it was good and hand spin has good comp stroke .
I did a search under air compressor and got to page 5 with no real results .
looking for the gasket #'s for comp to t-cover / adaptor on back of comp to let you bolt up the p/s pump and p/s pump to adaptor .
if there is even gaskets for the last 2 .
looks like I need to drain coolent also to do this job .
any help would be great guys thanks ! [thumbzup]
Suprman
707
Stratford/Connecticut
It's been a while it wasn't a bad job the power steering pump unbolts and the front flange of the compressor unbolts and the drive gear stays on the compressor and just pulls out. I don't remember the gasket number you can call cummins and give them the engine serial number they will sell you the 2 gaskets. A friend helped me with it I don't remember if we drained the coolant.
Andyrv6av8r
458
Spartanburg,SC
Where is it leaking? Why not just swap the cooling jacket and/or unloader head and leave the compressor body in place? I just did that on mine after; 1) replacing just the upper gasket under the aluminum unloader head; 2) replacing the unloader head with another used assembly; 3) this time I lapped the aluminum unloader head which was warped and is perfectly flat now, and did the same to the water jacket head which was fine. two new gaskets also. So far, it's running fine without a hint of a leak anywhere.
Coffey1
504
Gray Court SC
And he is the compressor expert that thing has given him fits and scared the crap out me.
I hate that little sob
sweetk30
9
horseheads,ny 14845
blown out at head to jug body in back pointing at engine block .
cramed my hand up in there with cold engine and full air buildup . gasket falling apart so brittle.
figured slide p/s pump back and 2 nuts on t-cover studs and few lines and swap whole comp for the good used one we have on hand .
sweetk30
9
horseheads,ny 14845
well the local parts stores are dumb or something ? ? ?
all they can find me is the air comp to timing cover gasket .
no one has a clue on the p/s pump to the back of the compressor . and I see the old gasket pattern there so I know there was one on there at some point.
anyone got part #'s ? ? thanks .
