M939 series TMs
5,189
This thread, and the one below, covers the M939 family of Trucks.
TRUCK, 5-TON, 6X6, M939, M939A1, AND M939A2 SERIES TRUCKS (DIESEL)
TRUCK, CARGO: 5-TON, 6X6 DROPSIDE M923
TRUCK, CARGO: 5-TON, 6X6 XLWB M927
TRUCK, DUMP: 5-TON, 6X6 M929
TRUCK, TRACTOR: 5-TON, 6X6 M931
TRUCK, VAN, EXPANSIBLE: 5-TON, 6X6 M934
TRUCK, MEDIUM WRECKER: 5-TON, 6X6 M936
The Following Steel Soldiers Members contributed to this thread.
@juanprado @Mos68x @WillWagner @KRedd @juha_teuvonnen @simp5782 @M1224 @patracy
The following Technical Manuals, are for Maintenance Instructions, Organizational Maintenance, Direct Support, Depot Parts and Accessories, for the A1 and A2 models. These TM’s pertain to all models. This list is for reference only. Check the NSN on your truck, and compare it to the NSN on the TM cover, to make sure it applies to your truck. Some of these TM’s may not be here because the distribution code is other then “A". Others, simply because we have not been able to locate them yet. If you see a mistake, please P.M. me and let me know. If you have a copy of a missing, or outdated TM, please P.M. me so we can try and post it here. @Guyfang
LO 9-2320-272-12: LUBRICATION ORDER FOR TRUCK, 5-TON, 6X6, M939 SERIES TRUCKS
MWO 9-2320-272-20-1 Restricted
MWO 9-2320-272-20-4: WRECKER AUTOMATIC THROTTLE KIT
MWO 9-2320-272-20-5: FRONT LIFTING PIN & SHACKLE KIT
MWO 9-2320-272-20-6: FUEL TANK VENTILATION KIT, MODIFICATION OF 5-TON M939A0/A1 SERIES TRUCKS
MWO 9-2320-272-20-7: BRAKE PROPORTIONING VALVE KIT MODIFICATION WORK ORDER - MODIFICATION OF 5-TON M939 SERIES TRUCKS
MWO 9-2320-272-20-8: MODIFICATION WORK ORDER - MODIFICATION OF 5-TON M939A2 SERIES TRUCKS, ACCELERATOR LINKAGE MODIFICATION KIT Restricted
MWO 9-2320-272-23-1: MODIFICATION OF 5-Ton M939 SPARE TIRE CARRIER REPAIR KIT
MWO 9-2320-272-23-2: MODIFICATION OF 5-TON M939A1/A2 SPARE TIRE CARRIER REPAIR KIT
MWO 9-2320-272-24-1: MODIFICATION OF 5-TON VEHICLE M939A0/A1 SERIES TRUCKS SPRING BRAKE CONTROL VALVE IMPROVEMENT Restricted
MWO 9-2320-272-35-1: MODIFICATION OF 5-TON M939A0/A1/A2 SERIES FAMILY OF VEHICLES (FOV) M939 BRAKE STABILIZATION PROGRAM (Retrofit of Anti-lock Brake System (ABS) for M939 FOV) Restricted
TB 9-2300-358-24: WARRANTY PROGRAM
TB 43-0001-62-03-1 (Extract) Brakes "M939 Plumbing Error Repair Kit".
TM 9-2320-272-10-HR: HAND RECEIPT COVERING END ITEM/COMPONENTS OF END ITEM (COEI), BASIC ISSUE ITEMS (BII), AND ADDITIONAL AUTHORIZATION LIST (AAL) FOR TRUCK, 5-TON, 6X6, M939A0/A1/A2
TM 9-2320-272-10: OPERATOR'S MANUAL FOR TRUCK, 5-TON, 6X6, M939A0/A1/A2
TM 9-2320-272-23-1: FIELD MAINTENANCE MANUAL FOR TRUCK, 5-TON, 6X6, M939A0/A1/A2
TM 9-2320-272-23-2: FIELD MAINTENANCE MANUAL FOR TRUCK, 5-TON, 6X6, M939A0/A1/A2
TM 9-2320-272-23-3: FIELD MAINTENANCE MANUAL FOR TRUCK, 5-TON, 6X6, M939A0/A1/A2
TM 9-2320-272-23-4: FIELD MAINTENANCE MANUAL FOR TRUCK, 5-TON, 6X6, M939A0/A1/A2
TM 9-2320-272-23-5: FIELD MAINTENANCE MANUAL FOR TRUCK, 5-TON, 6X6, M939A0/A1/A2
TM 9-2320-272-24P-1: REPAIR PARTS AND SPECIAL TOOLS LIST (RPSTL) FOR TRUCK, 5-TON, 6X6, M939A0/A1/A2
TM 9-2320-272-24P-2: REPAIR PARTS AND SPECIAL TOOLS LIST (RPSTL) FOR TRUCK, 5-TON, 6X6, M939A0/A1/A2
TM 9-2320-272-24P-3: REPAIR PARTS AND SPECIAL TOOLS LIST (RPSTL) FOR TRUCK, 5-TON, 6X6, M939A0/A1/A2
TM 9-2320-272-34P-1: DIRECT SUPPORT AND GENERAL SUPPORT MAINTENANCE REPAIR PARTS AND SPECIAL TOOLS LIST (INCLUDING DEPOT MAINTENANCE REPAIR PARTS) FOR TRUCK, 5-TON, 6X6, M939A0/A1
TM 9-2320-272-34P-2: DIRECT SUPPORT AND GENERAL SUPPORT MAINTENANCE REPAIR PARTS AND SPECIAL TOOLS LIST (INCLUDING DEPOT MAINTENANCE REPAIR PARTS) FOR TRUCK, 5-TON, 6X6, M939A0/A1
TM 55-2320-272-14-1: TRANSPORT GUIDANCE TECHNICAL MANUAL
In Addition, the following Documents are also included.
AMG ABS MWO FIELD SERVICE BULLETIN
CTIS TROUBLESHOOTING
M939 WIRING DIAGRAM
M939 TIRES
NHC 250 CUMMINS ENGINE PARTS CATALOG
M939 Series Anti-Lock Brake System Maintenance Sustainment Training
Transmission, MT 654CR, Operators Manual
Transmission, MT 654CR, Tips for Mechanic's
5,189
A few more...
