M998 civilian alternator not charging - new Delco installed (updated)
NDT
7,421
Camp Wood/LC, TX
For sure everything you add needs to be fused. And all cables going through holes needs a grommet. I will be visiting your incredible city here very soon and don’t wanna see a flaming hmmwv.
MattNC
271
Raleigh, NC
And you need all those 12V draws to be coming from a 24V to 12V converter that draws evenly from both batteries. Lots of us myself included use the Pyle units. I haven’t had any issues with mine but I put a heavy duty switch on the power leads running to it from the battery as step down transformers can draw even when not operating anything and I didn’t want them to kill the batteries when the truck is parked. Drawing high loads from one battery only is a big problem.
36
29
New Braunfels, Tx
So....new wiring, new 160 Amp 24 volt alternator, new 24-12 step down and fuse box. I also installed a full kill switch. No issues at all now. I have a ton of extra stuff to include 2 1500 amps, a sub and speakers, light bar, back up camera etc etc. Not a single problem. I appreciate all the help and advice.
Blue sea systems ST Blade ATO/ATC fuse block
Eaton Cooper Bussmann Sure Power 21100C00 Converter. - I had a small amp mounted in the smaller seat section and we still got this monster mounted.
160 Amp 24 Volt Alt kit from - thosemilitaryguys.com
Action
1,564
East Tennessee
How hot do those items in box next to batteries get? they have fins to help with heat disapation, but there isno room for air to move, or even ventilation in that compartment.
Are the batteries held down with 2-sided tape?
And, is it just me, or does the cable between the batteries look kind of thin...
