M998 Starter installation
Milcommoguy
2,120
Rosamond, CA
Can't go up... then go down. Pull the front wheels and let the truck down on some 2X4's .
Could work?
Hillbilly HumV garage, CAMO
TOBASH
3,057
Brooklyn, NY
What a bear. My jack does not have quite enough range. Suggestions on a less herculean technique?
1 or 2 6x2's under the jack? 1 or 2 6x2's on the jack lifting surface? Borrow a jack for free from one of the local car care chains that advertise free loaner tools?
cwc
144
Sweeden, KY
Have you tried just lifting it into place? Once you get the front stud in the bracket then the weight is a lot easier to manage while you get the first rear bolt in. It's good to have everything laid out in orderly fashion and good lighting. I like to have a long screwdriver in reach in case the shim(s) need to be shifted a bit. First time seems impossible, then it gets routine.
Sent from my E6910 using Tapatalk
osteo16
570
Evansville, IN
did it with old style bracket.... what a PITA... big forearms though 👊👊 and good for your rotator cuff🤣
just muscle up !!!!
Pussies and Humvees don't mix 😁
rcamacho
818
Bainbridge Island Wa
Done.
Used the floor jack to bring starter up to the frame rail. Rotated starter up into position and hooked stud on to new style front bracket - very helpful Then juggled the rear bolts into position with the shim.
osteo16
570
Evansville, IN
Done.
Floor jack...damn...that woulda helped me... Excellent idea 🤔
juanprado
2,737
Metairie/La (N'awlins)
Looked at this thread for inspiration as I need to replace my y pipe and think I need to drop starter to get to the right hand manifold. I take it with the starter off the pipe and manifold will be easily accessible?
springer1981
1,148
Maine
I did my y pipe with the starter in place no problem.
Mogman
8,393
Papalote, TX
Me too, the inside bolt was a PITA, I stuck the bolts in before putting the pipe in place and managed not to knock the inside one out so it went pretty easy.
papakb
1,186
San Jose, Ca
I'm an old man that's probably done half a dozen of these over the years and have always just lifted it up and rotated it over the frame by hand. There is no easy way that I know of, just bite the bullet and shove it in! :grd: Like Jack Kennedy said: "We chose to drive HMMWVs not because it was easy but because it
was hard (to fix 'em)"
juanprado
2,737
Thanks for the feedback!
Yes, the y-pipe can be removed with out dropping the starter.
Real tight. Heat shield actually has a hole so you can access one of the bolts.
I will post more details on my thread when I get done.
These 2 were my friends.
Action
1,552
East Tennessee
Can't you get to all 3 bolts on RH manifold by removing the doghouse?
