kfrosty
- 7
- 0
- Belmont, NC
I had a drive shaft break and replacing parts. The cap on the front shaft that comes out of the front diff and is in the Center support bearing lost a cap, so I'm looking to replace it.
Searing on ebay comes up with a 5-174x spicer. However, on my u-joint, one side has B7, the other side 151. In TM9-2320-280-24P Figure 136-2 shows it as item 21.
Item 21 21 KFOZZ 95019 2-5-848X .CROSS ASSEMBLY PART OF KIT P/N 5- 1 213X................................
I'm going to guess this is a spicer 5-213x?
Also, I broke 2 bolts in the yoke coming out of the front of the transfer case. Per the parts manual,
1 PAOZZ 5340011900807 95019 2-70-59 STRAP,RETAINING USE WITH T-CASE P/N 4 12340073-1.......................... UOC:H11,H13,H14,H15,H16,H17,H18,H20, H21,H24,H25,H26,H27,H28,MMM
1 PAOZZ 5340011900807 95019 2-70-59 STRAP,RETAINING USE WITH T-CASE P/N 2 5937387,12342643-1 AND 12447125.....
If anybody can confirm if the 5-213x is actually a spicer #. Also any idea of a spicer part # on the straps, I'd appreciate it.
I found 12339301 on HPG site which look to be the same.
I'll post if no response and get it figured out.
Thanks
Thanks
