M998 Weird Starting Issue
sbob4579
New York
Hi, I recently got a 1992 m998 HMMWV and when I start it, the battery voltage meter fluctuates steadily for the first 2 minutes. Could someone help me with this issue. Thanks!
Lionel
24
Baltimore/ MD
Perfectly normal as the glow plug controller continues to heat the GP's. I think only the S3 box stops this, but again, its normal.
jeffy777
VA
What Lionel said... I think it is called 'Afterglow' I find it is a good warm-up procedure not to move until after the truck is finished doing this process. You could get a s3 controller and I believe that has no after glow.
Lionel
24
Baltimore/ MD
Yes, I do the same with my '94, its the warm up period, unless its really cold out, then I wait till the temp needle starts to move. I wouldn't change it out unless you start to have problems sbob4579. Just my opinion, but why fix what isn't broken.
DLJIII
Bemidji, Minnesota
Mine does the same thing, I was afraid my batteries were weak or the alternator was acting up.
I dug around here and finally found the same answer but, I am glad you asked just as reinforcement for my peace of mind.
