- 8,698
- 3,205
- 113
- Monrovia, Ca.
Is the outside of the piston a clean aluminum color?
Yes, totally clean.Is the outside of the piston a clean aluminum color?
Yeah, the cup is swollen. That's why I suggested before to get an overhaul kit even for new old stock master cylinders. I've had a few do this right out of the box. Some even are so bad they completely lock up.Yes, totally clean.
I'd say most likely from the brake cleaner. It's hard on a lot of different plastics and rubber compounds.So if we're going w/ the cup being swollen I'm interested in how that happened.
This is an MC that has been in use (though I have been having issues w/ it),
has had dot 5 always,
I took it apart and did have to push it out from the other end (but not w/ a lot of effort if I remember correctly),
and it was out in the desert air for about a week before I put it back together.
Could this have occurred while it was in use? Or from being in the open air? Or from brake cleaner getting on it?
I'd like to avoid it happening in the future if possible.
You can buy cups alone. I have never tried to remove the seal on the piston. Also, brake fluid isn't a lubricant so it will not make the components slippery. Every MC or wheel cylinder I have built, I have used a product called McKays Brake Cylinder Assy Lube. Never had an issue, I use it for MC's and wheel cylinders we put into service or for the ones that are on the shelf for a faster repair.Thanks, and I have a rebuild kit from Big Mike that I've been holding on to and was hoping since the parts all looked good I could continue to save it for an emergency.
I'll use it to replace the parts I put back in. It would be nice if I could pick up just the rubber bits and keep them w/ the "not bad" parts that I have for a future use, "if needed".
Still interested in what could make them swell.
.The new parts went in smoothly and functioned as expected. Bled everything out to new purple and only the MC to slave cylinder showed any sign of crud. I did have to remove everyone of the bleeder valves and clean them out first as there's a little wasp that loves to fill them up w/ clay after laying eggs in them.
Not sure how everyone else is doing it but when it comes to getting the rubber boot back on the front of the MC I ended up turning it inside out back about a pleat or so and then rolling it onto the MC. I did have it on the pushrod first.
Now I just need to adjust the brake shoes as I have too much pedal before the shoes start touching.
Excellent! I was going to start researching just such a cap!.
You can eliminate the wasp laying eggs and plugging up your bleeder screws. There is an assortment pack and there is a #10 cap that will fit over the end of your bleeders @ Home Depot and other assorted hardware stores.
You also need to consider keeping the breather caps on your differentials unplugged.
Especially since you have the little varmits trying to plug your bleeders...
Regarding the boot on the front of the MC, I tried and tried to pop it on myself. Every time I would get half on and try to pop the other half on, the first half would pop off. So I had my wife from up top and I popped the lower half on from the underside. When she tried, it popped right on from up top.The new parts went in smoothly and functioned as expected. Bled everything out to new purple and only the MC to slave cylinder showed any sign of crud. I did have to remove everyone of the bleeder valves and clean them out first as there's a little wasp that loves to fill them up w/ clay after laying eggs in them.
I got my brake assembly lubricant from Euromotor Electric.You can buy cups alone. I have never tried to remove the seal on the piston. Also, brake fluid isn't a lubricant so it will not make the components slippery. Every MC or wheel cylinder I have built, I have used a product called McKays Brake Cylinder Assy Lube. Never had an issue, I use it for MC's and wheel cylinders we put into service or for the ones that are on the shelf for a faster repair.
I tried looking for the exact stuff, but me thinks they are out of business, however, I did find the same stuff just from a different manufacturer,
