Members in Northern Virginia?
CARMAN
86
Broad Run VA
I figured one of you was probably also bidding on the auction I was wondering if anyone was going there cause I can’t make it I might just give up on bidding
Not bidding. And Thursday is a 13 hour day...but I am around the corner from the stuff you are looking at.
Orionspath
Northern Virginia
Alexandria, Virginia. Hey guys. Does anyone has a 2’ square of Camo/green cargo cover Vinyl they’d be willing to share/sell me as mice must left me several holes in Deuce Cover last winter during storage. Cannot seem to find a repair kit WITH vinyl on line...Thank fellas.
Pete
Bulldogger
774
Quantico VA
I have cordura nylon in deep green by the yard. Be happy to send you a yard for cost of shipping. PM me address if you want it.
Bulldogger
pmramsey
190
VA
I have 2ft x 2ft peel and press vinyl sheets in OD green that is used for patching military parachutes. I use it on my trailer covers to patch the holes. I cut it to be several inches larger than the hole, affix it to the material, and perform the same on the other side of the cover. I've never had any issues with it. The patching material is re-enforced with a flexible screen looking grid built into each sheet.
USMCGunny
Quantico, Virginia
Woodbridge M35A2 1970 model
Its overheating and blowing water out of the cap. Original had the radiator repaired when I bought it a few months ago,the guys put it in the acid tank overnight and fixed a couple leaks and tested it out as ok. since then new belts, new cap, new sender, new gauges, new thermostat, new heater core. The system has been flushed back flushed and new coolant 50/50 put in the truck Yes the cooling system was a wreck. Well driving it 20 miles the other night the gauge went to just below 240 and when we got to where we were going water was coming out of the cap. With a thermal gun checked the temps and the top of the radiator was hot the bottom was cold. Both sides of the thermostat read the same so I assume its opening. U would think flow problem right. But the petcock drains the radiator with out a problem.
Ok all you SME out there what do you think, A new radiator is $1200 bucks
Another Ahab
4,954
Alexandria, VA
It sucks when you do everything right...and you STILL have a problem.
But it happens. Sure hope you get this figured out cheap, USMCGunny.
