MEP 002 battery group?
FMJ
37
Las Cruces, NM
I've been looking for over an hour now, got the NSN, got the size, but search has failed me regarding the battery group for the MEP 002
Crawdaddy
Louisiana
Copied from the Wiki
MEP-002A Battery
The OEM Battery is a 2HN 445CCA 45 Amp-hour 12V wet cell. 2 required (10.3"L x 5.3"W x 9.0"H)
BCI Group 51R is the civilian replacement for the military's 2NH battery. (9.4"L x 5.0"W x 8.8"H) The terminals are set-up the same as the 2HN which is reversed (R) from the size 51. Rumor on the web has it the 2HN is deemed not for civilian sale by Homeland Security. Don't know if true.
Other BCI Group sizes that might fit:
51 (9.4"L x 5.0"W x 8.8"H)
22NF (9.4"L x 5.5"W x 9.0"H)
45 (9.4"L x 5.5"W x 9.0"H)
Storeman says this one is a good fit: Interstate SP22NF batteries (requires 2)
Uloadit
12
Swansea Ma
This is what idid 1 x1 angel and bolted it to the frame and bolted one side of a bungee cordand hook up the other side to the frame .I used 2- 800 cc’s . 002a 2p.jpg
Uloadit
12
Swansea Ma
ya it said (( this 390 CCA automotive battery will get you where you need to go. )) LOL not far. That is no better that a lawn motor battery .One maybe two years and its done
edgephoto
Stafford, CT
the add on that site
Time will tell. Vibration is what does in lawn tractor batteries. I would be willing to bet that the vibration of the generators will be tough on batteries. Automotive batteries are not designed for significant vibration. I doubt that any civilian battery would hold as well as the Mil Spec battery.
Uloadit
12
Swansea Ma
They wanted $75 for each battery and that is 390 CC and don’t have the plates to hold up. I paid that for the bigger 800CC will get the glow plugs going quick.( more amps ) As far as vibration that’s not going to kill the batteries. But what ever! The cold and hot weather andhow long they sit with no charge will do any battery in. The more amps will also help make the starter last longer. and give you a lot longer cranking time
Triple Jim
277
North Carolina
The ability of a battery to supply current (Amps) is different from the current requirements of things like a starter or glow plugs. The starter and glow plugs will draw approximately the same current whether supplied by a 390 cold cranking amps battery, or an 800 one. The 800 version will probably supply it for a longer time before discharging, although CCA isn't a measure of battery capacity, Amp-hours is, which is somewhat related to the advertising term "reserve capacity".
