holley68
- 0
- 18
- Lumberton, NC
I recently bought a mep-002a in rough condition. Missing a couple of fuel lines and the voltage adjust switch. I was going to go through it just to make sure it's not worth saving first. I've pulled one fuel pump and clean it out. Was going to check to see if it worked. Hooked up two batteries and nothing. I am getting 24 volts from the batteries to the gen but nothing is happening. Battery indicator not moving. Check both connects by swapping the cables around. Still nothing.
Any suggestions?
Any suggestions?
