Triple Jim
- 336
- 83
- North Carolina
OK, you meant what you said.
Sorry I don't have the answer for you, however.
Sorry. S-7 is on other gen sets, not this one you have. Sorry. Working too many problems right now.S7? What is that. I looked through the manuals. Only thing I can find is the starter disconnect. Nothing to turn
So, what you are saying is that you turn the S-1 start switch to start, and the gen set starts up? And runs? Then as soon as you release the S-1, the engine shuts off? Will the set continue to run as long as you hold the S-1 in the start position? Remember, you can hold the S-1 in the start position, and it does not, or should not, hurt anything.The arm on the pump drops as soon as the knob is released. But the solenoid is still up. Any idea what would cause if from staying connected with the solenoid.
