Microsoft MSN, Live, Hotmail, Outlook email users may not be receiving emails. We are working to resolve this issue. Please add support@steelsoldiers.com to your trusted contacts.
I did a compression on all four cylenders and got 325 psi when i open up the fitting on the injector it stops smokeing the injector is near the fan shroud .I open up that injector and it looks clean and no whear marks any where.the cover that goes over the spring on the injector how much do i turn it down on the spring.The somke is grayesh white
you have to "pop test" it. That requires a test set-up to do adjustments. About 1,700 psi on the injector. It is not good to fool with injectors unless you are set up to adjust them.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
