storeman
- 52
- 48
- Mathews County, VA
Don't take offense at the basics below:
I don't recall you saying anything about adjusting valves, but I'd pull the valve covers, adjust valves and be sure that all ports are open on the oil pick-up/distribution pipe.
Oil flows to the heads through a port in the valve cover and is distributed over the valves, etc via small holes in the pipe attached to the valve cover. Pipe must be over the oil source hole in the head to pick up and distribute the oil. Might even use a bit of compressed air to blow down through the head at it's feed point to the valve cover port. Make sure the feed hole is not covered by the gasket. Gasket fits the head 2 ways, one is correct, one isn't. Little hole in gasket has to be on top of feed hole from head and unrestricted.
I assume the louvered vents below the exhaust are opening as required.
Jerry![A toast to MV's :beer: :beer:](https://www.steelsoldiers.com/images/smilies/beerchug.gif)
Jerry
