- 18,171
- 27,295
- 113
- Burgkunstadt, Germany
The only reason we jump A&B is to get the engine turning. G&H are part of the L1 circuit.
.Jumped the connector A& B plus G&H.
Put it in run and no pumps.
Don't forget, if the FL-2, (day tank float, tells the gen set its full, the pumps will not come on.
Battle on pumps running until it slowed down.
Battle off
Start mode and cranked for 20 secs, no start.
20 sec is not long, You can try it several times. Kris
.Ok
So I guess even though the battle will run the pumps for a long period of time in slow motion the pumps will not run when the day tank is full but the battle will still make the pumps work even though the day tank is full?
The S7 forces the pumps to run, regardless of fuel level in the day tank. FL-2, (day tank float) should tell the L2. (day tank fuel cut off solenoid) to close. Then no fuel should get to the tank. But the pumps will still run, just slower, because the L2 is turned off.
Will test S2-9 now
At the S2-9, yes. It turns into several other wire numbers, until it comes out at J37G. Then it P47J.So we are still talking about P47B?
