2Pbfeet
- 1,465
- 93
- Mt. Hamilton, CA
@peapvp great eyes on the wire. To me, that frayed wire looks as if it is almost burned in the photo.
That's for sure. That manual you guys provided is 1,328 pages and it sure bounces around a lot, but I am thankful you could provide it to me.Better get your reading glasses out
If you mean it looks like thisThat's for sure. That manual you guys provided is 1,328 pages and it sure bounces around a lot, but I am thankful you could provide it to me.
Otherwise I just wanted to check in and let you guys know where I am at since my last post.
I expect these parts in about a week, possibly sooner.
- New circuit breaker installed. Found the part I needed with a reasonable price ($54) at Powerwerx.com. Needed to remove the front cover's 24 10mm bolts to get to the back of the mounting screws because they had nuts and they fell off behind the wall that the circuit breaker is mounted to.
- Dicoovered that the air cleaner housing is missing the bottom and filter element. Could not find only the bottom so ordered a whole new air cleaner housing from dpequip.net ($115). The gauge that is to indicate the filter is getting dirty is also missing but I have not located that yet. I think the new air cleaner housing has a cap over this threaded coupling so I may not need this gauge right away. Ordered the filter element from amazon ($19), I hope that I ordered the right one.
- Ordered the banjo bolt and two washers/seals from dieselpartsdirect.com ($11 banjo bolt, $2 each washers).
BTW, I hope it is OK that I put the vendor's where I ordered my parts from in this forum. I have no affiliation and have no kick backs from that, I just want to provide it in case someone else also needs to source the same parts I did.
I also have a question:
On the control panel screen the oil pressure indicator is dark. I don't know how to better explain it, but most of the other indicators are lit. If this was a computer you could say the oil pressure gauge is "greyed out". I would provide a photo but the batteries are removed right now.
I thought that this gauge could be off because the engine is not running. Is that the case?
@peapvp - Yes, your screen looks exactly like mine - Oil Pressure greyed out also 3664 & 3664 errors.If you mean it looks like this
@BadAmish - that's what I am suspecting at the moment, connectivity problems. Could be a corrosion problem of the canon plugs as well.@peapvp - Yes, your screen looks exactly like mine - Oil Pressure greyed out also 3664 & 3664 errors.
I imagine that the old pressure sensor is on the engine somewhere and connects to the control panel.
If your control panel is showing the 3665 fault code because it is not connected to the unit, is it possible that mine is also disconnected somehow/somewhere?
@peapvp - Roger that. What did they used to say - "It's not a job, it's an adventure".@BadAmish - that's what I am suspecting at the moment, connectivity problems. Could be a corrosion problem of the canon plugs as well.
You have to crawl through every nook and cranny on this Genset.
@2Pbfeet - Thank you. Did you find it in the manual? If so, can you tell me which page?Part number 11675004 NSN 5340-01-059-0114 aka "Slave Cap Assembly" I believe. Available from many sources, you can try searching for "nato 1 pin slave receptacle cap"
e.g. https://www.eriksmilitarysurplus.com/naslrecowrec.html
All the best,
2Pbfeet
You are welcome. The learning curve at the beginning is often steep.@2Pbfeet - Thank you. Did you find it in the manual? If so, can you tell me which page?
@Guyfang - I used this one: MEP AMMPS 1050 -24 24P Manual smallDoes that help?
@Guyfang - Yes, that helps a lot, thank you.What manual number did you use to try and find the cap?
@Guyfang - I did not try looking through that manual as I thought I needed the "MEP AMMPS 1050 -24 24P Manual small" which I think is the same as "TM_9-6115-751-24P". I did save the "TM 9-6115-751-10" manual but for some reason thought I needed the other one for tracking down parts and troubleshooting. Lesson learned. Thank you.TM 9-6115-751-10
@Guyfang - Ok, and Thank you. Sometimes I feel impatient to get this unit running, but I want to do it right and not break it any more than it already may be.We have all had to learn it, one way or another. You are doing good!
@Guyfang - Cool, thank you. I've been on some boards where they get upset when one strays off the topic.Its your thread. Call it what you want. Do what you want. As long as it follows the Forum rules, you are the boss.
This may indicate that the wiring harness has an internal short somewhere which also caused the other wire by reconnecting board to burn up.I haven't been able to work on our MEP-1050 for a while and the new air cleaner housing came a few days ago and I was able to get that mounted this morning before the sun heats up. The new air cleaner housing came with a filter element cartridge so the one I bought from Amazon will be a spare. I test fitted the Amazon filter element - $19 - and it fits perfectly.
After mounting the new air cleaner housing I decided to take off the control panel - 4x 10 mm bolts - and look what I found:
I have not yet poked around in the manuals, but if I read that wire label is seems to be a shield / ground connection, also judging by the fact that it looks like it was connected to the generator housing.
Is it possible that this could cause the oil pressure and / or the 3665 fault?
I have not reconnected this wire yet in case it may have been cut for a reason.
@peapvp - Thank you for your reply. Do you mean I should test all wiring before reconnecting this cut / broken wire shown in my above photos?This may indicate that the wiring harness has an internal short somewhere which also caused the other wire by reconnecting board to burn up.
This will be a pretty involved trouble shooting.
You are most likely to have to continuity test each wire position in the canon plug to ground and to the end of that wire position
