MEP-802/803 relays
Daybreak
2 Star Admiral
1,522
774
Va
Howdy,
Both the MEP-802A and MEP-803A use the same relays.
The relay are all the same, EXCEPT, the one on the far left. It is SPECIAL.:wink:
Guyfang
27,014
Burgkunstadt, Germany
They, the new ones, are nicer because you can see the red flag move when the relay opens or closes. Don't know if the relay itself is better, but I never had many relays go bad anyway. A few, but on the whole, they were not a problem. The few I found, I always used for training aides.
Daybreak
2 Star Admiral
1,522
774
Va
Howdy,
Yes, the farthest left piece is actually a switch. That is the pricey one $$
nextalcupfan
508
St. Joseph Missouri
Does anyone have a part # for the "new" relays put in with a reset? (The ones with the flags) I would like to keep 1 on hand as a backup but cant see a # for the ones Hard Head posted.
I found an Omron Relay (Omron MJN2CF-DC24) that should work but I want to search the "new" relays before I purchase anything.
(P.S. I looked up the Potter & Brumfield ones, I can get one easily but they are made in China now while my originals were made in Mexico. I would prefer not China if at all possible)
kloppk
4,167
Pepperell, Massachusetts
It's possible. S14 is used for disabling the starter and flashing of the gen head.
Best to refer to the -24 TM and use the troubleshooting steps for engine not cranking. Could be a few culprits in the circuit causing a no crank situation.
