MEP-802a / 803a fuel pump connectors
Digger556
823
Denver CO
One of my units is missing the connectors for the main fuel pump, both on the pump and harness side. I have tracked down the part numbers for the pump side housing and pins, and the housing for for the harness side, but I'm struggling to identify the correct P/N for the harness side pins.
Any help would be appreciated.
justinn
33
THE GREAT STATE OF TEXAS
and if you are dead set on replacing it with the same connector, it's just a molex 2 pin(I forgot the pin diameter). You should be able to find them at a real electronics store, or online as long as you know the pin diameter.
Ray70
7,113
West greenwich/RI
Most times the old hard copy Molex catalogs would tell you the mating pin series# on the same page as the connector / pins that you located.
Maybe they show the same info on-line if you look up the Series / PN of the half you located?
But I would also just go with M/F .250" Fast-On connectors like L.I.T.D suggested.
Digger556
823
Denver CO
Unfortunately I dont even like these Molex connectors, but I wanted to return this unit to a OEM condition, giving me the abilty to swap pumps easily if necessary.
From the TMs, it is easy to track down the housing numbers, but the pins are proving to be more trouble. Worse, the datasheet for the housings lists several pin series and it is going to take some leg work to figure out which one was spec'd for the MEPs.
Guyfang
27,146
Burgkunstadt, Germany
OK, Boys and Girls, pay attention here. Below is a picture of the E2 fuel pump. Note that the plug is P13.
Go to the -24P. Look at the Figure 12. Output Box/Engine Harness Assembly. Find J13. Item # 42. Part #: 03-09-1022, Item name: CONNECTOR BODY, RECE
Put this part number in your handy dandy search engine. Hit enter.
Search Results
Molex Connector Part Number - 03-09-1022
Molex
https://www.molex.com › part-detail › crimp_housings
03091022. 2.36mm Diameter Standard .093" Pin and Socket Receptacle Housing, 2 Circuits, without Mounting Ears, with Ramps, Natural. Status: Active active.
The answers are in the BOOKS!
Digger556
823
Denver CO
Thanks Guyfang for helping me understand how to read the harness diagrams, I'm glad I ordered the right housings. Here is the parts I ordered:
Fuel pump connector housing:
Molex 03-09-2022
Harness connector housing
Molex 03-09-1022
The pins were the hardest part to figure out. I ended up ordering spares from Green Mountain under the TM P/N and measuring to determine the Molex series
The fuel pump pins are male, series 1190. I used Molex 02-09-2101 part number (tin plated brass)
The harness pins are female, series 1189. I used Molex 02-09-1102 part number (tin plated brass)
