I have a feeling it's not a matter of a gummed up pump. These pumps are simple magnetic plungers, not rotary motors, so a stuck pump doesn't pull high current like and electric motor's LRC. You probably have a shorted pump or an issue with the float module.OK,
Whenever I set the generator to aux fuel it runs for about 2 seconds then trips the breaker. House tank works fine.
My theory is that the pump is gummed up maybe from the leftover sesame seed oil in my drum?
Any other ideas?
Hello,I think you will find either the pump or the double float aux fuel sensor in the tank has shorted (I have had both do this). Take the cover off the fuel tank, and deenergize both. Plug one in at a time, and flip S1 to PRIME + AUX and see which is the culprit.
Do you have one for sale?And no, its a pluck and chuck part.
I'm a big fan of brass floats. I've never seen one fail.As I have been working on this I realized the original floats are foam and the new one has polymer floats. Why anyone would design a foam float to sit in diesel fuel for years, I don't know. Hopefully this one lasts forever.
But, we can't get these sending units with brass floats unfortunately.I'm a big fan of brass floats. I've never seen one fail.
Maybe we need to figure out a way to repair or rebuild them.Unbelievable. I reached out to the manufacturer of these floats... To order (IN QUANTITY 50+) they are over $250/ea now!
I don't believe that will be possible. Probably have better luck finding someone who makes something similar, and find one that isn't an exact... but might work. Kind of like that company who makes the fuel level senders... KUS? Maybe they have a comparable beast.Maybe we need to figure out a way to repair or rebuild them.
I was thinking that you or @kloppk could design one, build it and then market it here on this forumI don't believe that will be possible. Probably have better luck finding someone who makes something similar, and find one that isn't an exact... but might work. Kind of like that company who makes the fuel level senders... KUS? Maybe they have a comparable beast.
