Surf
- 0
- 0
- Hawaii, United States
I have recently purchased a trailer mounted MEP-803a. The fuel drain was not attached and looks to have been knocked off. It is still attached via the retention chain but the hole is not plugged with the drain. Looks like the "grommet" or "plug" was not installed straight just off the looks of it and it was probably knocked off easily. I did a lot of research, read all the manuals, including the parts manual and searched numerous threads here and on other forums.
I have not had much luck other than, this is indeed a weak spot and not an uncommon problem. I have also heard of fixes involving various mesh or fill type of "patchwork" on the hole. My questions are;
1 - Is the drain valve simply a press fit for retention in the gas tank drain hole? Cannot find a retaining nut on the inside of the tank. Parts manual does not appear to show one either, so perhaps the drain neck and petcock is a press fit assembly?
2 - To me the Tech manual is really unclear on the "grommet" or "plug", but rather shows what looks to be the corresponding part as part number 38 and lists it as a "nut". (38 XDOZZ XB XBOZZ 07707 A3816 .NUT 2 2) Part number is A3816. This looks to be the "grommet"?
3 - Searched for the part number replacement with no luck. Anyone can point me in the right direction, it would be much appreciated.
4 - Anyone have pics or advise on how to plug the hole? I have thought about tapping the hole and plugging it, maybe a petrol based thread sealant and washer? Even thought about a helicoil set up. Any thoughts?
I have attached a couple of photos and any and all advice on solving the issue is appreciated! Open to part for replacement / repair to just plugging the hole.
![](https://scontent-a-dfw.xx.fbcdn.net/hphotos-xpa1/v/t1.0-9/10676237_1561343770746823_5219100428904455977_n.jpg?oh=81099b814c89017944b63e79f472804e&oe=54FF3B2A)
![](https://scontent-a-dfw.xx.fbcdn.net/hphotos-xap1/v/t1.0-9/10676339_1561344260746774_6642739693516567865_n.jpg?oh=f097d7a668755392f1f56cac17caa630&oe=550EEAE1)
