MEP-803A Repair Assistance
justinn
33
THE GREAT STATE OF TEXAS
Of the 2 sticky ones, I was able to polish one of them and get it operating smoothly. I think the other one may be a lost cause though. I will attempt once more to fine polish it and get it operating correctly. Small steps on the polishing front!
That said, it will now hold a 40% load without hunting, even with the other slightly sticky IP. At 100% load, it now hunts about 7 Hz, which is way better than before! So if anyone has unsolvable hunting issues, check for sticky IP's! FWIW, they look spotless and could easily pass for new. Once they heat up, the tolerances become slightly too tight and it has a drag on the IP.
Justin
CallMeColt
1,726
Wilson County, Texas
Justin
Good find. I'm sure it can still be cleaned up. Usually they will get loose if they're worn out, not tight.
justinn
33
Just a final update....
After basically "blueprinting" the #3 IP, it still had a slight drag when hot(running for 10+ minutes when under 80+% load). The fluctuation was slight, but present and you could still feel a slight drag on the rack when hot. I removed the IP once again and went over it with a fine toothed comb. The only other issue was that there was an over so slight nick on the upper part of the piece that slides in to the rack(the circular piece that sits inside the IP). I carefully filed that down, polished it up, reinstalled and she now runs like a champ at 110% load. It was a long journey, but through pure stubbornness, I prevailed! The super odd thing about all of it is that gen had never even had a bolt turned on it, so it would have had to been in there from manufacturing.
Thank you all for your help and suggestions, and I feel much more intimate with these 8xx series now :ROFLMAO:
Now on to the HMMWV's for a bit
Justin
loosegravel
Just a retired mechanic who's having fun!
504
893
Enumclaw, Washington
Justin
It’s good to know that good governor control really depends on good IP health with these LP engines. Your determination has paid off! Great work 😁
CallMeColt
1,726
Justin
Glad you found it! I had an MEP-016B that had a slight nick on the regulator that caused issues as well. Injection Pumps are very fine tuned machines. Digging in can be irritating, demoralizing, and make you want to toss tools. But, once you do get it. It gives you that good feeling that if there is an issue down the road, you will know exactly what to do next time.
justinn
33
A few tools were indeed tossed! I think that's an actual step in the TM(or at least it should be). "If you have tried all of the above and are still experiencing an issue, grab the 3/4 inch wrench and chunk it at an inanimate object; Then try the previous steps again"
Justin
dutchofsc
Sc
Adding my similar experience so others can search.
I got my mep803a with 20 hours, no reset. Check a few things, threw in new batteries and started right up. When it got to temp, the engine started surging, dropping rpm then revving up with black smoke. The surging would get out of hand and i would shut the engine down. After reading many posts, I added a whole can of sea foam and a quart of atf to the half full day tank. I repeated the start and warm up then shut down process several times, allowing the engine to cool completely each time. After several clock hours of doing this, the Gen started to run better each time, lasting longer before surging and surging less. One time I stated it up to find it was actually holding and running fine.
While troubleshooting the issues above, I tried adjusting the droop, in and out up to 7 turns (half a turn at a time), it made no difference, set that back to where I started. At this point the gen was running good but it sounded off, and I could not get to 100%. Eventually I found injection pump 1 was loose, as in the threads on the ip were the pump splits in half were not fully tight, weird but you never know with these surplus units. After this, the generator runs amazing, was able to load it to the max 130% for several minutes, and I did a 40 hour test run powering my house, everything checks out.
Best of luck.
