Mep 803a voltage regulator
technoid
14
Middlebury center, PA
My machine has the fuse installed to protect the field if the regulator should short. My question is does anyone know if a new improved regulator is available that has higher PIV rated diodes?
technoid
14
I use to work for a public water utility. I was their senior electrician and technical trouble shooter. I worked on many large generators in the 350kw and up range. Our older units that dated back to the 1960's had outdated mechanical relay AVR's. I dealth with a company called Basler. All they needed was the resistance of the exciter field winding disconnected and the operating voltage. They had a solid state AVR for any generator. I upgraded many. And the responce time of the droop was so much faster. Since I am retired I am going to call them and see if they might have one for the 803. Maybe a much improved model thst wont blow out from start surge.
mlaxton
Florida
Did you get anywhere with this?
