- 1,201
- 1,464
- 113
- Basehor, KS
That's interesting. Germany switched to 400VAC from 380VAC years ago and I believe so did NATO.Years ago in North America, 4160 was a popular distribution voltage, easily divided by a 10:1 ratio to 416.
It sees use only in non-upgraded facilities here.
All Generators have the 24 VDC NATO Receptacle and other NATO members use those MEP's or AMMPS as well.
The Equipment is interchangeable.
I read somewhere if a 3 Phase Motor is rated for 460/230/208 then this motor can run on 416 (2x 208 ) which would make sense
