Okay,
I have finally fixed my CIM's screen issue that I first mentioned in this tread:
http://www.steelsoldiers.com/showthread.php?162166-Mep-805b-display-issues
I replaced the LCD panel, and it didn't make a difference, ghosting issue was still present. I decided to check the resistance of each conductor in the ribbon cable from the CIM's computer motherboard to the the LCD panel, and I found several circuits with very high resistance. I pinpointed the excessive resistance to the area where the large ribbon cable connectors "crimp" on to the ribbon cable (the terminals of the connector pierce through the insulation and make contact with the conductors in the cable). I removed the connectors, cut off about 3/8" of ribbon cable, cleaned the barbs of the connectors' terminals with DeoxIT, and carefully crimped them back on. Retested the resistance afterwards. Looked good, so I reassembled the CIM and tested it. Works perfectly!
